Spark Plugs for Stryker Race Heads
spotter
What are people using for big turbo applications?
Thanks..
repiv
Thanks..
depends on the boost level your running in terms of heat range (not sure if that was the question)
as far as brand, i've run autolites racing plugs in my turbo car, ngk's for colder heat range (autolites aren't resistor at certain heat ranges)
as far as what plum said, its a good idea to see what your builder recommends, the plugs I run are the ones UR runs
Camfab
SoCal
Not everyone uses a specific tuner or has an engine builder, but as I've found here most owners are completely clueless. Not a dig but just a simple fact, lots of money here, but few actual gearheads. It can be frustrating when your looking for a simple answer.
repiv
He asked specifically about "big turbo" cars, its unlikely in this instance he doesn't have an engine builder/tuner.
Either way I'm pretty sure I gave him a clear answer in what I use in my car.
BTW spotter I run the Stryker's in my car as well.
spotter
Personally I don't like going by only one person or tuner's recommendation and would like to hear what other people are using.
I think people are often led blindly my there tuners.
Just trying to see what people are happy with and not happy with.
Isn't this what the forums are for?
Didn't realize it was such a sore spot for some people.
Seems like a lot of drama on the viper forums.
That's why I usually stay off of them.
spotter
Did you like the autolite's or ngk's better?
Viper X
I don't have a "big turbo car", but I do have a big Paxton car, 925 rwhp with Stryker heads at only 11.5 psi peak boost.
I've had very good luck with Denso Iridium IKH24.
You may want to contact Jeff Morey, the maker of Stryker heads, for another opinion.
Dan
repiv
no notiecable difference to me. again only reason i went to ngk is that in colder heat ranges the autolite plugs aren't resistor
good luck!
Mando9595
