jmillsUT28
Car is running like crap. Everytime when I start the car it runs rich and idles poorly. After I run the car and burn up the fuel it starts running better. I did a search on here and found nothing. Did a search on the other forum and found if the MAP sensor is not tighten down then it will cause this problem. So I looked for the MAP. This is what I found below! A hose where the MAP should be(I would guess) going to the split second box. Then found the MAP wires(would assume these are) cut and taped not connected to anything. Does the Split Second not use the MAP sensor?
