SRT and jack stands?
Polka
Green Oaks, IL
I am ready to put on my new Corsa track system exhaust, but I don't have a lift and I need to just jack the car up. Where should I put the jack stands at? I can't find a single good place to do it. Any help would be appreciated.
Cape Coral, FL
may want to use/make drive-ups for the SRT. most of the frame is covered by the belly-pan, and should not be used to lift the car unless the pan is removed. due to the shorter overhangs on the SRT and the higher ground clearance in front and back, some drive-ups can be used. A 3-4 stepped stack of 2x8's with 6-8" long levels works VERY well.
Callaghen
