Starting Problem.....
Newport Viper
Newport Coast, CA
1995 Rt/10. When I press the clutch to the floor turn the key... nothing? With the clutch depressed to the floor, I will then wiggle my foot around and it will catch (start). Is there a switch in the clutch that is loose or broken? Thanks in advance for help!
Ron
Indianapolis
<FONT face="Comic Sans MS">All manual transmission vehicles since at least 1970 have a switch on the clutch linkage under the dash the prevents starter motor from receiving +12v unless fully depressed. It appears yours is in need of adjustment. Should be easy enough to do if you're fairly limber. Could also just be a loose plug.</FONT f>
