Street alignment with some track use
Schulmann
Canada
I have to impove my alignment espetially the front. The PS2 tires on my 2006 Coupe are loosing "chunks" outide... Obviously the camber is not enough. I have read a couple of good threads on alignment but they all focus on track alignement.
I need a compromise between street and track use. After reading I was thinging about the following setup:
Front: -1.5 Camber ; 5.5 Caster ; +1/16 toe out
Rear: -0.8 Camber ; -1/8 toe in
Viperless
MN
Looks good to me but I think you could be a little more aggressive on the front camber. Mine is at -2.5 and it's a street car that sees occassional track duty. I'm not seeing any unusual wear like I did on the rears before I had them reset to -1.0. But I'm at neutral toe on the front so that helps a bit with tire wear.
YLW DRM2
No more suggestions ... :(
I have the same question. I do occasional track days, but I notice that my outside of the tire wears out more than the inside, so I definitely need a little more aggressive set up, but still be able to drive on the street without wearing out inner rubber in few thousand miles.
Schulmann
Canada
This is what we did today:
FRONT: -1.73 toe-out +0.12
REAR: -0.90 toe-in -0.31
Handling is stable on highway and city traffic.
I am curious to see how it will handle on track and especially what my tire wear will be ...
