T-Stat Question
TRACKDAY
Woodbridge, VA
Hello all,
I have a 2009 ACR and was thinking about installing a 185 degree thermostat to help the engine run cooler during track use.
I had one installed in my previous track car which worked well and was wondering if the Viper's big V-10 would benefit from a similar set up or if the OEM thermostat is sufficient.
Any and all input is welcome.
Thanks :D
Allan
La Junta Colorado 81050
.........Also have the SCT tune from Roe that turns the cooling fan on sooner.
About 180 if I remember correctly.
Changing the coolant every year at the beginning of the season. -whether it needs it or not.
Replace the radiator hoses every other year as well. -just because.
Dan Cragin
LA, CA
If you drive in cold weather with a cooler thermostat with an 08-09 Model. It could go into Limp Mode. I use a 170 thermostat in our ACRX's, but do not use it on the street cars.
T
TRACKDAY
Woodbridge, VA
Allan.....good information :2tu:
T
TRACKDAY
Woodbridge, VA
Dan.....I don't drive the car in the winter months. Would you recommend the 170 thermostat for an ACR that sees track use a few times a year?
Thanks :D
Cape Coral, FL
Hello all,
Thanks :D
Your car already has a 185 thermostat. Leave it alone.
