Tech Question: PCM Functions
Earl_H
MI
I have found that the stock pcm controls voltage regulation. Does it also interface with the speedometer and vehicle speed sensor.
ViperJohn
Maryland
I know it interfaces with the speed sensor. I believe that is how it receives vehicle speed info.
I think the speedometer operates off the rear end and is not connected to the PCM. (But not 100% sure about this.)
PhoenixGTS
Phoenix Arizona
Yes - thus creating the opportunity to run the little gear ratio correction boxes sold to give you the right speedometer reading after you change gears. Pins 27-28 on the white PCM connector.
