Temperature Mark on Gage?
cayman
Missouri
What is the approximate coolant temperature at the first large hash mark left of the 250 red zone on the gen II temp gage? I'm guessing 220?
GR8_ASP
Doesn't the scan tool simply interpret the sensor, which itself will have variation unit to unit?
The sensor has 2 elements. One that provides the signal for the gauge and the second for the PCM for engine control. The OBD provides the PCM temp.
dave6666
Um. Did that answer my question? :dunno:
Unless you are calibrating the PCM to a particular sensor with a scan tool then the variation of each sensor is still in play, right? And I'm not talking about the 2 sensors in each housing. I'm talking about a batch of complete sensors will vary sensor to sensor.
GR8_ASP
Well I guess if you are worried about the sensor error you must be worried about the infrared sensor error also. Correct? And I think you should have the sensor checked and the whole engine calibration reset due to the error also (said tongue in cheek). The sensor accuracy escapes me at the moment, though I did know it about 15 years ago when it was first developed. I guarantee that the temperature drop across the radiator hose is a larger error factor.
But whatever, the temp sensor has high enough accuracy as it is used as one of the inputs that determines the fuel and spark calibration, which is a bit more important than the gauge position. It is also evaluated against the ambient temp sensor and inlet air sensor at cold starts to ensure that all 3 are operating properly.
dave6666
OK. I agree that there's probably little variation in the sensors from one to another, and that also the IR has a tolerance itself and could be off a tad bit.
But I've got a decent quality IR (~$90) already in my toolbox, but at what $$$ would I have to add a scan tool also?
Some of this will always depend on what weapons are in your arsenal. :)
GR8_ASP
True Dave but at some point the scan tool will become a requirement. Plus, you can get the one that allows you to upload performance software.
I get codes way too frequently as I burn out O2 sensors like they are candy. I continue to use them for a long time after they throw the first code (always the same O2 heater ...). So as long as I have the scan tool I can check things like oil temp, coolant temp, inlet air temp, etc with good accuracy. Even O2 to make sure the sensor is actually working and only the heater circuit response is off.
ViperTony
Dan at ViperSpecialty recommend to me PCMSCAN from Palmer Performance. I'm going to order it this week unless there's something better out there.
Jack B
NE Ohio
Try EASE and Auto Enginuity, they are both pc based. Buy an Acer net book and you have a super portable scan tool with unlimited logging capability. The Ease package can be had with a wireless connection to the OBD port.
ViperTony
Thanks for the tips Jack. :2tu:
