Thanx to JD, my engine is starting to look like it should.... :)
ROGUE
SoCal
I second NAPA. And if you are gonna use an impact or a power-tool to install them, put a little bit of anti-sieze on the threads...
JD
Dear god buddy, please tell me you have never ever used an impact or air ratchet on a T-bolt clamp... please please tell me you're just joking in some not funny, very scary way.
btw have you opened it up on your sled yet? I hear it's been running around town but you haven't gotten into it yet. Put your foot in it and lets see some wide open, 20psi 4th gear data logs.
If little ole me can handle that car I'm sure you can. :2tu:
P
plumcrazy
ALL OVER
got the intercooler figured out and mostly hooked up, installed the heat shields over the bellanger headers and installed the spark plugs. still need a few hose clamps and a hose but its bascially done.
http://www.plumcrazy.com/moparstyle/IC2.jpg
http://www.plumcrazy.com/moparstyle/engine_IC2.jpg
http://www.plumcrazy.com/moparstyle/engine_above2.jpg
http://www.plumcrazy.com/moparstyle/engine_IC_above.jpg
next sunday we should be able to finish up the I/C, fan, radiator hose clamps, install the new hood hinges and get the fascia figured out and prime the fuel system and check for leaks.
Im really pushing to get this dang car started and running on april 1st one way or another.
P
plumcrazy
ALL OVER
pretty much just got the fascia cut up to clear the huge intercooler today. had to take off a lot more than i expected but it fits now. im not real sure what to do with the hood release yet...but the fascia isnt actually bolted up yet.
http://www.plumcrazy.com/moparstyle/IC_installed.jpg
http://www.plumcrazy.com/moparstyle/IC_installed2.jpg
http://www.plumcrazy.com/moparstyle/front.jpg
and i got the new hood hinge in and it clears the radiator hose enough for now. soon as i get it running im gonna try to get a pipe bent up for it and then get it chromed.
http://www.plumcrazy.com/moparstyle/hood_spring.jpg
then put some juice to the fuel pump to check for leaks and had a bad one at the rail. it looks like the O rings are old and hardened. so im gonna replace all of them this week. and found a real small leak at the fuel pickup in the rear at the tank. im hoping just a little tightening will fix THAT.
if all goes right this week and i can get all my parts, im gonna try like heck to fire it up on saturday. and if all goes well, put the hood back on.
Dimitrios
Queens, New York
oh wow. looks awesome. i had no clue you were doing a S/C. ive must of been out of the loop. way to go kiddo.. shes gona run strong! BTW nice pics over at the other site. you're a nut!
pedro
N.Y. USA
Starting to look pretty good.I just got back from island Dragway mustang blow a head gasket. :hitfan:
P
plumcrazy
ALL OVER
pedro, when ya going up on that dyno ? i might wanna take the ide with ya if ya dont mind. i wanna talk to them and check that place out.
synfull, thanx its getting there now.
P
plumcrazy
ALL OVER
ok, will do.. thanx for the heads up on it.
i told ya jim, i need all the help i can get, PLEASE keep the help coming...:)
ctrengine
