Tips and install time on a VEC 2?
Blue Streak
How much time can I expecct to spend this weekend installing my VEC2? Any helpful hints? Thanks
Mr Hemi Head
Bluemont VA USA
Give yourself as much time as needed and have fun!
The most difficult part is routing wires from the VEC into the passenger compartment. Removing the black plug, on the drivers side cowl area, will provide a path without drilling holes. Use a fish wire (bent hanger)but be sure to disconnect the battery since the fish may contact the rear of the fuse holder. Protect the wires by harnessing with electrical tape.
Schulmann
Canada
1st time 3 hours
2nd time 1 hour
Best time: 18min 23sec
Just follow the instructions.
Personal advises:
Use a ground on the main frame and never use an existing ground. My prefered ground location is structure supporting the engin. Use a stable +12v source activated by the relay.
Mando9595
