Clean area around chip THOROUGHLY.
As mentioned above, add a little touch up paint at a time to build up the hole (chip) to a level ABOVE the surrounding area. Now the fun part, go to your wifes favorite make-up store, and buy some various grit fingernail emory boards, you know for fingernails. Get VERY, VERY, fine grits, down to some that at called buffing surface (no grit).
Take scissors and cut the boards to a rounded, narrow tip, and "file" away the excess paint, using finer, and finer, grits (usually 2) as you go, down to and including the 'buffer' board.
Try to disturb the surrounding paint (clear coat), as little as possible. Use as polish or light swirl remover to finish up.
Make sure area is clean of all wax, etc., before starting.
Later,
