I am fitting Eibachs to my 2000 GTS which I use for road & track here in the UK, I have checked the tracking before fitting and it shows 1.5mm toe out at the front is this normal, does anyone know what it should be.I am also planning to gain a bit of negative by removing the shims.
My shockers were set to fully soft but there only appears to be 1.75 turns of adjustment is 1.5 turns front and 1.25 turns rear about right, I don't want to set it to hard and loose traction.
