Transmission noises
Matt Dumas
worcester mass usa
I just brought my 96 GTS home from the dealer last night.I was wondering if all Viper transmissions have slight wining noises? Its nothing that sounds like its going to self-destruct but it reminds me of how the old mopar 4-speeds would sound.Also ,I read a TSB about the neutral idle rattle.What is the cure for that or should I just live with it?Thanks for your help!
Ron
Indianapolis
<FONT face="Comic Sans MS">Matt,
Compared to my 1970 Trans Am with an M-21 4 speed, the Viper tranny is almost silent. Sure it does have some mechanical noise, but nothing unpleasant and in my opinion much quieter than I remember the old Mopar cast iron 4 speed.
The neutral gear rattle is normal and from what I hear the best bet is to just get use to it. Changing fluid type might help, but in cold weather shifting is more difficult. A dampened clutch plate might help, but since you're out of the factory warranty it'll be expensive and I don't think it eliminates it anyway. I just think of it as part of the car's personality.
I would suggest however, finding your local chapter of the VCA, joining quick and comparing your tranny sound with another Viper. With only a 90 warranty from the dealer you'd better be sure the trans is healthy, quick! Otherwise you could be spending $3500~$4,000 big ones...</FONT f>
Y2K10 SRT#39
Olympia, WA, USA
Go to your dealer- get the '99 spec syn trans fluid. Drain and replace. Run for a couple days to see the difference.. Made a wonder of difference in my 96 gts
ctrengine
