trickle charger/batt tender
jman2
Hello all,
Had a trickle charger (you plug into the cigarette lighter) from a late 90's porsche), would this also work for GEN3 vipers? I figure it's probably the same as one you would buy from the store?
J
TommyG
San Antonio
I use one that also is for a porsche, mine is a 996 turbo. Plug it into the console under your arm rest area as that one stays live. I alternate bt the pcar and viper. Works great and I don't have to fool around with the battery or other wires. Mine is a ctek unit.
viperbilliam
Richland, WA
I use the Battery Tender 800 unit. I just hook it up through the front grill onto the remote battery terminal for the red clip and the thermostat bolt for the black clip. Just raise the hood, unclip, and pull through the grill when you want to take her out. Just remember to do it before you pull out!
J
jman2
Thanks folks, i think my old cig lighter plug in from the porsche should be fine :)
J
naimsito
