Turbo gallardo...639 rwhp 7.5 lbs of boost!!!!!!!
bad viper
san bernardino,ca usa
jason said THE motor LOVES TURBOS!!!
wITH A DIFFERENT FUEL MANAGEMENT system 800 rwhp
would be eaisly done.
at this level driveline components... halfshafts ,transmission
would surely go south.
So I advised him to leave it there. this converts to 751 Flywheel with a 15 % loss a full 225 rwhp better than my 414 pre turbo dyno.
He will send video to me tommorrow. CAN'T WAIT
Fast Freddy
TUCSON, AZ - USA
that is one trick gallardo you got there. :cool: can't wait to see the video of that in action. i assume your vid is of your bull on the dyno. man i bet that lambo would make for some killer street races on a roll. take alot of those new C6 Z06's by surprise and even a few modded vipers too. my hats off to you for building such a unique ride :2tu:
GTS Bruce
Orchard Park,NY,USA
I am impressed.Looks like the whole pkg was done right.Far better to do it like the way you did than to waste driving time constantly fixing broken parts that wern't upgraded to match an upgrade. GTS Bruce
RedGTS
Tennessee
Was it dynoed with the front drive disconnected or was it done on an AWD dyno?
B
bad viper
Re: Turbo gallardo...679.9 rwhp 7.5 lbs of boost!!!!!!!
tweaked fuel. then on way to strip fried stock clutch when heb floored it in 2and. I knew 12000 milestock clutch would go soth I just hoped for a couple of Passes first.. Anyhow 1000 HP tilton goingb in the Morning.[pollstop]
BOGOTA
NEW YORK
INSANEEEEEEEEEE. Very impressive. I can not wait till I buy my LAMBO, hopefully soon. I want a 03 MURCI.
B
bad viper
murcie enginews have steel sleeves from factory Gallardo did not. Jasoin had to have those made.Murcie engine MUCH better
Casey
Valparaiso, IN.
"The Little Engine that Could" ! :2tu:
Awesome numbers and I bet it will just ROAR!! :headbang:
v10kingsnake
south jersey
that man can do anything you can imagine, it only takes the balls, and the wallet size willing to drop the thousands needed to make it happen.
BADVENOM
port washington, n.y. usa
Believe or not Jason said no..Oh well just have to live with 500 HP
Casey
Valparaiso, IN.
Jason said NO! LOL
That man has to take a BREAK every once in a while!
stevnme
