Twin Garrett GT4067RS turbos
INSOMNIAC
Europe
Twin Garrett GT4067RS Dual Ball Bearing, Water Cooled and Ceramic Coated Turbos For Sale
These are the very hard to find Garrett GT4067RS Dual Ball Bearing, Water Cooled turbo that are high temperature ceramic coated to keep the surrounding area temperature low. They are good for 800 HP each.
These turbos are brand new. The GT4067RS are the upgraded Garrett GT40R Dual Ball bearing turbos. They spool up very fast but still make tremendous amount of power throughout the rpm range and at the peak.
They were originally ordered from Precision Turbos for my 05 Heffner Twin Turbo Viper but I decided to go with different turbos.
Here are the specs of the turbos.
<ul type="square">[*]2 Garrett GT4067RS Dual Ball Bearing, Water Cooled Turbos
[*]S Cover Housing
[*]T4 Tangential turbine housing
[*]Designed for 3 inches downpipe (can be altered)
[*]0.81 A/R on the turbine side
[*]High Temperature Ceramic coated turbine housing
[*]0.70 A/R on the compressor side
[*]Rated for 800 HP each.
[/list]
The Garrett GT4067RS turbos cost $2,274.99 each from Precision Turbos without the ceramic coating option and it will take at least a month to build if you ordered them today plus the time to ceramic coat them.
The cost to duplicate these turbos would be $4,549.98 + $400 for ceramic coating = $4,949.98 plus shipping.
I’m asking for $4,000 plus shipping.
Any takers? PM me.
jdoc7
Just curious why you bought them for $5000 only to change your mind for something else? What are you replacing them with and why?
I
INSOMNIAC
Europe
I bought the Garrett GT4067RS thinking that they are the biggest ball bearing T4 frame S cover turbos. And they are actually. Then, I realized I would need something bigger to achieve the numbers I want on the pump gas and recently I was able to get a custom GT72 ball bearing turbo built for me.
These are the upgraded Garrett GT40R turbos and are rated to 800 HP each.
Dale04SS
