Valve cover spacers for Gen 3 covers on Gen 2?
Jance GTS
Oklahoma City, Oklahoma
I have a set of Gen 3 valve covers that are going on my Gen 2. I know there are a few different valve cover spacers I can get, but which ones would you recommend? I've heard the ones on ebay for $300 are junk? Which ones are you using if you have done the swap and have you had any issues with them?
Thanks!
rpm9000
Texas City, Tx.
You have a PM.
Thanks!
MTGTS
Orlando, Fl
This the the machine shop that actually makes them
BilletRacingParts
MODERATOR EDIT: Link to non-site sponsor removed.
VIPER BAZ UK
ENGLAND
You will need to mod the breather outputs on the Gen 3 covers as they breath out the top and not the front..
Also you will need to mod the way your wire clips work.. I screwed in some threaded bar,put covers over and used SS nuts to secure covers and then pushed wire clips down on the threaded bar (like the Gen 3..
Re-use your Gen 2 gaskets on the heads to spacer as the Gen 3 covers have a seal built in...
The only issue i had was contact with the Roe intake tubes....
I used SS button head allen bolts to dress it up a little...
trydh
Sweden
Does anyone have those valvecover spacers for sale ?
I have looked around but have not found any yet.
I found one that had them but I thought that $700 for the spacers was little overpriced !
Any help would be appreciated !
Or if anyone has a used set for sale.
/Jorgen
xeng yang
