VEC2 question
ViperBite
Orchard Park NY
First let me say I do not have any documentation on the VEC2 system on the car. It was on the Viper when I bought it and the prior owner did not provide any documentation when the car was sold!
Couple of days ago I disconnected the battery to do some maintenance. Prior to the disconnect the VEC did not have any lights on. Today I happened to fire it up with the hood up and noticed the first (left) green LED was on. The light was on solid meaning not flashing. What does this mean?
Quantico, VA
PM me with a fax number and I can possibly dig out some paperwork. Sean would be a good POC as well....he's busy as heck, but always willing to help.
DSR207
Gulfport, MS
It means it's ok, I have one and that green led stays on when the car is running, like it should.
ViperBite
Orchard Park NY
So if the light was not on as it should have been does that mean anything? I will keep an eye on it to determine how it works over a period of time.
Tony, I think I will call Roe and see if they are willing to fax me or send me a PDF of the basic instructions on this device. If that seems problematic I will PM you.
Thanks for your help and advice. :2tu:
Sean Roe
Jacksonville, FL
Hi ViperBite,
Below is most of the info you need now.
Give us a call or e-mail me if you need further assistance.
Front Panel Indicator Lights and Smart Card Write Button Functions (from left to right):
- LED #1, Green, Power. Indicates power is on.
- LED #2, Red, User selectable features (activated in the Box Configuration menu).
- LED #3, Red, System busy or error. Lights steady during the reading or writing of a Smart Card. Flashes if there is a system or card error. Steady on with the #4 green LED indicates the last card function was a write to the card.
- LED #4, Green, Smart Card read / write. Flashes when card read complete. Steady on after a card writes with the #3 LED.
Pushbutton, writes current settings from the VEC2 to Smart Card (allowed only in UNLOCKED mode). Push button before sliding card into slot, otherwise, it will read the card instead of writing.
VEC2 Smart Cards
The VEC2's Smart Cards are actually small computer chips that contain fuel and timing curve programs that operate the engine. They are durable and can be kept in the car or in your wallet. You can have an unlimited number of cards (programs), with settings for different fuel, boost, nitrous, injector sizes, etc.
To upload a new Smart Card into your VEC2:
1. Turn the key (power) on. The far left green LED will illuminate.
2. Slide the Smart Card into the VEC2, gold chip side face up and forward into the slot.
3. The red #3 LED will illuminate momentarily while the card is being read. Once the card is read, the light will go out and the green #4 LED will begin to flash.
4. Remove the card.
To write your current program to a Smart Card:
2. Press the write button to the right of the LED's and hold.
3. Slide the Smart Card into the VEC2, gold chip side face up and forward into the slot.
4. The red #3 LED will illuminate while the card is being written. Once the card is written, the green #4 LED will also illuminate. Once the green LED comes on, the writing is complete and you may remove the card. The VEC2 will only write to the card if in the unlocked mode (see software manual for details).
The more of a change in the program being written to, or read from, a Smart Card, the longer the process will take (from one half second to about 3 seconds).
If the third red LED flashes when a card is installed, this indicates and error (i.e. wrong card for that system or dirty connection). When this light flashes, the VEC2 did not accept the program you were attempting to load. Try wiping off the card and re-loading. Otherwise, it may not be properly coded for that VEC2.
Regards,
Sean
[email protected]
ViperBite
Orchard Park NY
Sean,
Thanks!!! :2tu:
I sent you an email with a couple more questions. I really appreciate the help, now have piece of mind.
