Viper Error Codes
Hi, Joe. My 95 service manual says that a MIL Code "12" is "Battery Disconnect"....further says "Direct battery input to PCM was disconnected within the last 50 Key-on cycles." It has a footnote that further says "Check Engine Lamp will not illuminate at all times if this Diagnostic Trouble Code was recorded. Cycle Ignition key as described in manual and observe code flashed by Check Engine lamp." Hope this helps. GOOD LUCK,
Steve
naimsito
