Heres my take on what your to expect with the new gears.
The 3.55's are shorter winded than the oem's. The G-force pull is higher, but shorter in duration than the 3.07's.
Traction is actually more improved, because the 3.07 will make the car bog, or spin without much control or visa Versa. The 3.55 will spin easier, but is more controllable, with modulation of the throttle. I can't really explain what I mean. This subject came up a few years ago in the GTS forum and It was very well explained.
You may notice a lag in the car when you get the new gears because you have to get on it and out of it quicker, you can't drive it like you did with the 3.07 in it. You will be going out of the engines torque range quicker. The lag you feel now is the car is just geared to high and if it is hooking up on good pavement, the car hasen't enough torque to pull its self up quickly.It will take more on the gas than before to make the car go with the 3.55's in it. You will have to learn how to sprint about differently. The red line is there before you know it. The back lash when you let off the gas sooner than the clutch is more obvious now. Hand and foot timing must be improved. The car will pull harder with this gear in it. Get on some good pavement, and punch it at about 3000 or so rpm, and get ready to shift a moment later. The long G-force is not there, but more intense.
Gears must break in. They are very tight when new, part of the tight feel you are getting.
The lower gears come with some annoying factors, but as you relearn your driving, they will become more fun.
I have said the optimal gear to be a 3.33, unless you raise the tire size as I did. But most people think more is better. ET slicks will really go with the 3.55's. When the Pilots are hooking up, but spinning a bit, you really become over geared, as this makes it hard to work the car right. Better traction will make the gears nearly a perfect combo.
The Viper is a car that with a hand full of mods, can actually do well with a 3.33
The total time doing the complete job, 6 hours on a beginer, that knows this type of work in general, and four to five hours when he gets good at it. Most places will rob you on it, because it's a Viper I guess. All in all it's a very simple upgrade for a gear guy.
Practice sprinting about before you do any drag racing. You will have the car nose diving between gears, and bumping the red line, even a few gear grinds, as the car is throwing you around more with this new explosive pull in first and second. I really hate the top section of the seat. Volvo was the only car I ever seen that thought the top half of your back should be resting against the seat regardless of where the seat back position was. Terrible racing seats in the Viper.
Skip W.
