I need to know what the stock pump's PSI is at idle and wide open throttle.
Anyone please??
Thanks!
Anyone please??
Thanks!
Not yet. I have one and need to put it on. I have about 50 PSI at idle. What PSI is it suppose to be at full throttle?
On my paxton set up at full boost, I am seeing about 80 PSI which I should be seeing 100 PSI from what the directions tell me. I checked to see that both pumps come on which they do, but maybe they don't have enough pressure to get me to the 100 psi. Only thing I am afraid of is if the injectors go static on me because I think Paxton pretty much maxs them out.
What lb injectors should you go with on a sc set up with 700 rwhp??
Dan,
most of my questions have been different each time about fuel injectors. What you taking such a big offense to this? Or are you just trolling me? None the less, I will always ask questions even if it doesn't doesn't agree with you.
Dan,
I am not taking offense, just seems you are asking these questions for attention and not for knowledge as they have already been answered.
