What is the Torq spec for the 2000 oil pan and gasket
"Lifetime" Y2000+ Pan gasket only goes on one way......fittment provisions are made for rear main seal cover and front timing cover, where they bolt to block.
Be sure to add some gasket sealer at least in these prone-to-leak areas......if not the entire gasket. Top side/Block side of the new gasket really the only area needed. Sealing entire gasket still OK !
Ron
Indianapolis
<FONT face="Comic Sans MS">Silicone Seal or something stronger?</FONT f>
Mark Red GTS Cooper
Gainesville, VA, USA
It seems like all the bolts except for the head bolts (under valve cover) are 95 in lbs,
The injectors hold dowms, valve covrs, outer head bolts, manifold.
Plus, they are all the same bolt! Jason Heffner said that Dodge got a good deal on them :cool:
Mark
