What paint for Stripes?
Hissses
El Cajon,Ca
Need the paint type/mfg and color code for the factory white stripes on a 1997 GTS.
SUN RA KAT
Guest
Exterior paint - see Sherwin-Williams.
You can get a paint roller and masking tape there, too.
H
Hissses
El Cajon,Ca
I think the roller process only works on the YELLOW ones :D
Ron
Indianapolis
Most Vipers were painted by ASC with Akzo Nobel paints. (a few early 1998's had PPG). Sikkens is the retail equivalent of Akzo.
As far as stripe application goes, the body panels are completely painted with the base color and cleared, then the stripe outline is masked and the paint is lightly scuffed (not to primer). The stripe only is then painted and cleared. After the baking process the stripe is lightly sanded with 2500 grit paper and polished.
BarryLB
