It is not necessary to remove the PS pump itself (if you don't want to). The cross member in-front of the PS unit will need to have the two (2) bolts from each end removed. This will allow movement vertically to get a puller/installer on. You will need a PS pulley remover to get the OEM one off. Most auto parts places will rent you one. If you cannot locate one, PM me. When putting a PS pulley on, the end of the PS shaft MUST be flush with the pulley surface. If it is not, premature belt wear and/or failure will result. You can use a bolt and some washers to do this but an installer tool is easier (they have a bearing inside). There is a lot of stress on a "bolt and washer" when pressing on a PS pulley. This may cause the washers to "cup" under the pressure and not give a flush fit. An installer tool will not do this.
