Here's some old notes from back in those days I posted on the Alley........ First outing was an 11.5, then went back and got 11.35 @125....
http://www.viperalley.com/forum/viper-discussions-gen-i/76991-frogs-98-gts-1-a.html
http://www.viperalley.com/forum/viper-discussions-gen-i/90858-frog-s-98-viper.html
Not an ideal time to go to the drag strip... We all know HEAT is the enemy when it comes to racing or trying to reach a speed goal. It was 105 degrees when we left the house in Austin and 105 on the highway before we pulled into the track at San Antonio Raceway. A friend of mine said his girlfriends
car
, out in the parking lot in Austin, read 111 about the same time we left to go to the track. My goal originally had been for a high 11 because this car felt faster than my RT/10 that ran a 12.1, but ideally with this heat, I was more expectant of a low 12 second pass if things went well...
However... Viper came though!!!
Here are the details for any of you interested or wanting to know more about my setup.
When I installed my Eibach Springs a few months back, I adjusted my shocks. My shock adjustment settings are as follows... First tighten the shock at full tight (clockwise).... then backed off to:
Front - 1 full turn back off
Rear - 1/2 turn back off
I had my rear
tires
" 345's - BFG G-Force Drag Radials" on 18" HRE's, at 22lbs of pressure. There was ZERO tread, so only sticky flat surface left, which is good... BUT, I BARELY had any tire left in the rear at all and needed to make sure I could make it back home (about an hour drive) so I couldn't go ALL OUT with burnouts. I think smoking the tires would have netted me better results but I just couldn't do it. I basically went around the water box as much as possible and did a few clutch dumps to dry the tires off. I tried to launch around 4000RPM's and since I was on drag radials, I could pretty much get into the gas fairly quick off the line.
For my shift points, I upped my shift light to 5700RPM because the Dyno showed some power left at the top (my RT/10, was set at 5200, so trying another shift point in this car).
I didn't really ride the clutch out this time, like I did with my RT/10, so after the launch, it was gear bangin time!
Results - VIDEO Below:
http://www.youtube.com/watch?feature=player_embedded&v=IuYkULeO1zE
I'll try to post a video soon. Here is the info below from tonight at the drag strip. I'll mention my mods, in case folks find this post in the future doing drag race searches on here, and my mods in my sig change in the future. I'll also list other important data for folks interested in specific details, like me. I did not do a "full", smokey burnout... Only a quick high rev and then dump the clutch to spin the tires HARD and get the water off my tires.
Mods for this pass are as follows:
98' GTS with 01' "Creampuff" motor swap
A.R.T. Dyno puts my
car
at 455HP / 499TQ (I actually lost a few HP after installing the roller rockers. Before the after market RR's, was 461HP / 507TQ)
SVT "Race" Headers
No Cats
Side Borla mufflers (no rear mufflers)
Eibach springs & Lowering caps
Raptor shift light
Aluminum Fly wheel
A.R.T - SCT Tune (93 octane pump gas)
Harland Sharp Roller Rockers 1.7 (got these used, not brand new)
K&N filters
Smooth Tubes
BFG Drag Radials 345/35/18
Removed spare tire & Jack
Track temp - 70 degrees.
Approx 700ft elevation in San Antonio TX
Car weight, with driver included, on track scale - 3,485.
60' 1.76
1/8 - 7.39 @ 97.74
1000 ET 9.5
1/4 mile - 11.35 @ 125.00
I'm VERY Happy with this time, considering the few mods I have. I was hoping to get closer to a 10 sec pass, and feel like I could have done a little better, but I didn't get many runs in and didn'd have enough tire to do GOOD burnouts (as usual, lol)).... Other two passes were 12.1 @ 108 (eh... blew the tires off, at the launch), and 11.7 @122 (spinning hard in each gear, had to let off the gas, temp was 65 degrees at this point). This should have been a GOOD ET because it was getting cooler out car was moving FAST, but just had no traction).
Had a blast tonoght! Hope this info helps you guys out!
