White Goo
Gerald
Near Tampa Bay
hmmmmmmmmmmmmmmmmmmm, white gooey substance coming out of a "pipe"??? Sounds strange to me.... Heck I've NEVER seen that before....
errrrrr
Gerald
Mike Brunton
N. Andover, MA
Hmmm, maybe someone has been "admiring" your car when you weren't around?
Sorry, couldn't resist.
There should be nothing in the sidesills that would cause this. Are you the original owner? My guess would be that someone probably put something inside the sills (either heat paint or header wrap) that isn't working, and it's liquifying and dripping out.
Pull the sill and take a look - it's easy to do. If the paint is bubbling, you can *probably* get it fixed under warranty. Others have, but others haven't also.
If you have not been putting bangers n mash in the crankcase, then maybe you have a sidesill that has been repaired?
I cannot visualize the complaint, but it sounds like a defective repair. Can you "probe" the area with a pencil eraser ("rubber"
in English)
Fort Lauderdale, Florida.
ELECTROLYSIS;
Most common among older R/T 10's. Dissimilar metals create a galvanic cell causing them to literally eat each other. I've heard of removing the rivets and treating them with a zinc chromate primer, then repaint.
Good Luck,
Doug
