White Smoke on Startup
SYNFULL
Bucks Co, Pa
I get a blast of this everytime the car has been sitting at least overnight. I am hoping it is just the water/**** that is spraying some moisture in the intake on statup. Anyone have this with the w/m setup or should I be more concerned?
Gary
D
DAMN YANKEE
Guest
Add more water and don't pack so tight....
Omaha NE.
Could be a slow head gasket leak when the motor cools and contracts pulling the water in. Would probably have it looked at before there is a bigger issue.
dave6666
A couple of checks...
Is it one pipe or both? A head gasket leak or valve seal leak would show up on just the problem side. Unless you have 2 problem sides. The water/**** issue would be common to both sides unless you inject into each manifold runner separately.
Start the car with a piece of cardboard right near the exhaust outlet. Burned oil is smoke and will not spot the cardboard. Water/coolant/**** is a vaporized liquid and should spot the cardboard.
Mccarlin
Chicago, IL
generally it's the valve seals leaking when you see white smoke on startup and then goes away after the engine warms. It's the head gasket if its the opposite, white smoke after the engine warms up, not on startup.
Omaha NE.
Wouldn't valve seals leak oil? (blue) and not coolant (white)
dave6666
That might be breaking the color spectrum down a little too much for a guy sitting in his car having a *** moment!
Really though, I've alway considered oil smoke to be white. Can't say I've ever seen coolant smoke. At least knowing it was coolant.
johnk
Laplata, Maryland
However, when the car sits and cools, coolant can be drawn into a cylinder or cylinders. If the leak is bad enough, not only will it blow white smoke/steam on startup, but it can hydrostatic lock the motor. As me how I know....:crazy2:
SYNFULL
Bucks Co, Pa
I just had all the seals replaced with viton seals. I hope it isn't that. Also new gaskets. It only lasts for like 2 seconds and then it's gone. Is it possible that it's the water/****? I think I read that it does prime when you turn the key on. I guess that's a question for Sean Roe.
Simms
Pittsburgh, PA
It's just a quick little prime. I wouldn't think it would be enough to make the car smoke, but I could be wrong.
Any type of smell to the smoke?
I believe that one will find that Mobil 1 gives a whitish smoke vs. the blueish smoke of non-synthetics.
SYNFULL
Bucks Co, Pa
No, I just checked both spots. I put a white t-shirt over the pipes when I started it this morning. There was nothing on the shirt when I took removed it. Don't know exactly what that means?
dave6666
Well, the white t-shirt wasn't entirely the right tool, but if it was black it would have told you you're running rich.
Don't think you're investigating black smoke right now.
The t-shirt is too porous/wrong color to catch anything else. That's why I suggested cardboard. Like maybe the brown corrugated kind. You might have to have someone hold it for you while the car is started, or tape it to something to hold it.
And if the white smoke only lasts a few seconds, you'll need to be moving quick to see if anything splattered on it like water vapor etc. The hot exhaust gas will dry it if it gets wet very quickly.
Might best be a 2 man job.
The mention of smell was also a good one. Burning oil and water vapors ain't the same when it comes to a sniff test.
Once again, might need someone standing back there when the car is started to catch a quickie whiff.
