who makes a playback boost guage
Achilles99
Atlanta, GA
Greddy and HKS do, but it'll be in BAR instead of PSI...
DEFI makes a pretty cool line of linked gauges as well.
Also, I'm not sure if the playback feature is available in 2 1/16 inch. Where are you mounting it? The next size up isn't that hard to install, with a little dremel work...
Joseph Dell
Atlanta, GA 30338
Autometer has one that doesn't do playback, but it does tell you what the peak boost was from the last time it was checked. I went with that one...
JD
Jack B
NE Ohio
Joe & Twin Vipers:
I just bought (this week)an Autometer electric fuel gauge and found out that they have converted most of their electric transducer/gauge packages to a 0-4.5 volt output. I believe any of their gauges manufactured after 5/1/04 are this way. They are trying to have all their gauges capable of feeding into their new logger.
I have an Innovative air/fuel logger that has the capability of five additional inputs. I now have air/fuel, rpm and the fuel pressure input into the logger. The new autometer electric gauges now have an output set of pins on the gauge, not the transducer. I mounted the gauge under the hood and ran the data from the gauge into my logger.
All you need is a logger. I would highly recommend the Innovative logger, or you might want to look at the Autometer setup. IMO you should start with the a/f and everything else is icing on the cake. In your case if you watch boost and not a/f it could be catastrophic
Dash mounted gauges are all show, you cannot accurately watch all the gauges and give adequate attention to driving/shifting/stopping. The air/fuel is the worst it is almost useless unless you can log. The fluctuations are too great and come too quickly to get an accurate reading with a gauge.
If you check Autometer go directly to the factory, the retail outlets don't even know about the conversion.
Jack B
NE Ohio
Why the low preessure gauges, the gauge you want is the 100 psi full sweep. The vipers are going to fun 55 psi.
