will a 97 cam work in my 94?
IEATVETS
Cottage Grove, Wis.
You wouldn't hear the lumpy sound over your LOUD exhaust anyways! I have heard that it will not work but I am by no means an authority on the subject. :D
XS TORQ
San Jose, CA., USA
I do not believe the Gen II cam will work in a Gen I. I have the same grind as a 96 in my Gen I, but it was made specifically for a Gen I. Valaya (my local tuner of choice) got it from Dan Cragin.
Larry Macedo
Sanford, FL
The 908 cam from the 97 works great in a 94 as an upgrade. You will need to use a Gen I timing chain set as the Gen II timing chain set is not compatible in a Gen I, unless you are utilizing AEM.
martyb
IL
I think the 708 will work fine in the Gen 1 Mitch. I thought about making that change with my old Roe car, but then I decided the 708 was too small. Ended up with a custom grind, I think just over .600 and 232/236 duration, 114 centerline I believe.
I miss the lumpiness of my old car, the GTS idles like my Lexus!!
martyb
SNKEBIT
SNKEBIT
western wisc.
Holy crap Larry!!!!????!!! You getttin lost in old posts these days????:lmao:
martyb
IL
Damn Mitch, I didn't realize this post was from the stone ages!!
happy
p.e.i canada
will it fit no prob in the 02 gts??? id like to swap cams this winter i know its alot of work for that ruffer idle.. lol
SNKEBIT
SNKEBIT
western wisc.
I think it's relatively the same cam as a 708, your newer engine has different lifters in it. (different bleed down rate for emissions)
I think if you put in the "older" lifters, it'll be lopier again. :dunno:
mbccenter
Legacy Supporting Vendor
Forest Lake, MN
I thought you were loosing your mind as you put one in a 94' a couple years ago.
plumcrazy
ALL OVER
there are much better cams than the 708 for our cars. talk to greg good about it. if you are gonna go thru the trouble of replacing a cam, might as well make it a good one.
while doing a cam, might as well do the heads as well and really take advantage of the cam and get a lot more HP. again talk to greg good on this.
martyb
IL
The overlap in the 96-99 was 6 degrees more than the creampuff cam also. That, along with the lifters, killed our lopey, musclecar idle:mad:.
happy
p.e.i canada
so is it true by changing out the stock lifters and putting some t&d lifters in you would get the lopey sound/idle back liek the 96 to 99 years??
Dan Cragin
LA, CA
708 cam will work fit 1992-2002 Vipers. Gen 1 and 2000-2002 models will need a new computer calibration.
Ross L
