Willow Springs Testing 1 2 3 14" Rotors Pic's
D
Dave's Big Brakes
San Diego Ca USA
Re: Willow Springs Testing 1 2 3 14
final testing 4 wheels big brakes
Big RaceYellow Calipers :D
D
Dave's Big Brakes
San Diego Ca USA
Here's the info on all 3 types of M/C's
Gen1 = bore & stroke (1.54 & 1.125)
Gen 2= bore & stroke (1.54 & 1.125)
Gen 3= bore & stroke (guess what? 1.54 & 1.125)so the only difference is the size of the res.
Non ABS= very small
ABS gen2=very large
ABS SRT =very,very large
all with a 65/35 split, and this is right out the manual.
Watch for new post Monday under New Products & Suppliers Special for pricing on bracket kits and options.
Tom F&L GoR
Wappingers Falls
Dave, do we have a typo somewhere:
Service manual says
Gen 1 & 2 bore is 27mm (1.063")
and stroke is 32.17mm (1.266")
D
Dave's Big Brakes
San Diego Ca USA
Hey Tom,
OOOP's Non abs cars are 1.063'x 1.266' and ABS Gen2 & Gen3 are the same
Page 5-8 in the manual is.
Bore and Stroke 39.0MM X28.57MM, or (1.54 in x 1.125 in)
same for the gen3 cars per The "Wizzard" out of the manual.
Thanks for the catch :eek: )
Dave :D :2tu:
Tom F&L GoR
Wappingers Falls
My ooops, too, I said Gen 1 and 2 are same, when it is really Gen 1 and 2 non-ABS are the same. Now we know Gen 2 ABS and Gen 3 ABS are same. Cool.
jrkermode
Los Altos, CA, USA
Dave,
In all your brake testing did you ever experiment to see if wheel choice makes a difference in rotor temps?
jrkermode
Los Altos, CA, USA
So all your testing is done with the VR-1's? No testing with stock '02 wheels or with the Purners(?) in your thumbnail.
D
Dave's Big Brakes
San Diego Ca USA
Still working on 02 18" and Purners, need to mount new rear brkts for fit. Every wheel is different on fit only, backspacing is the problem.
Should have final info on wheels shortly.
jrkermode
Los Altos, CA, USA
I obviously was not clear in my post. Let me try again.
I have heard that different wheels "breathe" differently enough to influence rotor temps.
Based on your pictures and signature, I'm guessing you have a good variety of wheels; stock '02 wheels (slotted mags), Purners (mesh) and VR-1's (spokes). I was wondering if you found any differences in brake temps simply by switching wheels.
It's not a fit question, simply a case of whether different wheels help the brakes run cooler.
D
Dave's Big Brakes
San Diego Ca USA
What are you going to be using this setup for? I didn't take any temps, when using larger rotors and bigger pads, temps will be cooler, than the stock gen2 junk. Gen2 stuff is way over used causing higher temps. These calipers and rotors are all OEM SRT's.
jrkermode
Los Altos, CA, USA
I already have a big brake kit for occasional track use. I was simply wondering if switching away from my stock (2002) wheels would decrease my brake temperatures.
D
Dave's Big Brakes
San Diego Ca USA
Do you have brake air deflectors? they help a lot, I'll have them under new products shortly too. Open wheels are better, if nothing else than look pretty :eek: )
Let me know what you choose.
jrkermode
Los Altos, CA, USA
I have StopTech 14" Fronts, stock rears, BM3 pads, stock '02 wheels, stock tires, Cone cooling and deflectors.
Without measuring temps how can you say deflectors "help a lot"?
SingleMalt
Read: Brake fade.
D
Dave's Big Brakes
San Diego Ca USA
Well, FINALLY :2tu: :2tu: :D :usa: Kits will be available next week listed under New Products and Suppliers Specicals :usa:
Stay tune for the pricing and what fits what :cool:
Porsche isn't the only one now with cool calipers. Viper owners will be able to have Big Reds & Bigger RaceYellows :cool: or any color they want.
P/B calipers are next on the list, for you guy's that use P/B's :)
VANTA'SVIPER
SANDIEGO,CA
Dave if you need to test 2001 wheels for temperature we can set a date aside and you can use my wheels for testing on your car.
Just call me and let me know.
D
Dave's Big Brakes
San Diego Ca USA
New post over on New Products and Suppliers Special
Thanks to everyone that helped with this product. :usa:
The Wizard,Woodhouse,DC Performance,Paul,Tom H,Willow Springs Raceway,Bugeater, and to the SD Viper members, Thanks
If I left anyone out, it's called CRS :D :2tu: :usa:
xeng yang
