Window issue
kennyhemi
Miami Fl
Ok Guy's, I notice last night the when I close the passenger side door I heard a pop. It appears that the window is not moving down when I open the door, causing the glass to catch on the edge of the roof line when I close the door:omg: It does move! just no enough. Which brings up the question is this adjustable or must the window modulator needs replacing. I have warranty until Oct 09 providing the parts available.:(
Martin
It probbly came off the base - which was really common on Gen II cars but I thought they had it sorted it out for later cars. Definitely get it fixed while you can :) Having your passenger push the windown down while pushing the 'open' button gets old...
MoparMan
Las Vegas, NV
Had a similar issue with my '06 coupe's passenger door - the window wasn't dropping far enough when the door was opened. The dealer's fix was to replace the window lift under warranty.
Flash1034
San Juan Capistrano, CA
Mine does the same thing occasionally. It *****!
Flash
[email protected]
I had the same problem. Dealer fixed it under warranty. They suggested that if this occurs again try resetting the window by holding the window button down for 10 sec.: keep in mind I was told this when I picked my car up I have no proof this works.
Mpcc
