window rattle
Geoff Green
Greenwich, CT
Has anyone experienced the passenger window rattling when going over bumps on a 98 GTS? When I roll the window up a bit it will be less, but will still rattle. This is no major problem, but if there is an easy fix I would do it. Geoff Green
Matt M PA
Langhorne, PA USA
Geoff...see if the felt pad that holds the window is adjusted correctly. It is high up in the door, and has an adjustment. On my '96, even after adjustment...it still rattled when you would close the door. You may have to remove the inner door trim panel to get at teh adjsutment.
rlamorte
