Window Tint Advice
sbkim
Bloomingdale, IL
I am thinking about doing 20% tint all around. The darkest I had so far in my other cars was 35%. Is 20% too dark at night? I wanted 20% so I can hide my stereo equipment in the trunk (GTS). I guess I can do 35% front windows and 20% in the back but don't want a mismatched look.
Thank you
tim721
west milford, nj
you should be fine with 20%...35% is too light, and wont hide your stereo too well
i have 5% on my car and backing up can be tough, go with the 20
dont mix and match, go the same all around, i think it looks better
Venom 1000TT
AZ USA
I had 5% on & it was too dark. It took away from car's appearance. I went with 20% & it looks way better. IMO. :smirk:
Don
Colorado Springs, CO
Do whatever is legal in your state (i.e. ~27%) There is nothing worse than having to scrap it off on the side of the road due to some officer having a bad day. I do recommend tinting the rear as dark as legal. It helps when a truck or higher than average car pulls up behind you at a stop light at night.
yellow02
NY
From a person who has 20% onyx tint... i think it looks pretty good, and at first i thoght it was pretty dark. However, its def not dark enough to cover up ur stereo. I just spent about 3 grand myself in subs and amps, so i might have to do darker myself.... or get a trunk cover...?
S-JC
20% should be pretty good for covering up the stereo, unless the speakers are very close to the window. I had a Daytona and an Eclipse with subs and 20% tint and never had a problem.
Agreed 35% is way too light and 5% is too dangerous. 20% is a great medium. I'm planning on doing 20% within the next month.
CHAD
Sarasota, FL
I just did 20% on the rear and 30% on the fronts and like it. I think any darker up front would be difficult to see the x-mas tree at night.
And it doesn't look like two different shades of tint at all. 20% up front would be the absolute max and you will give up some night time visibility. The stock Viper headlights are bad enough without adding to the problem.
Chad
No members online now.
cowger2
