YouTube Clip
zen garage
Glenview Illinois
i do not know the exact weight difference between the two. the stock ten spokes are no slouch in the weight department. the fact that the startechs only come in a 20/20 will add one heck of alot of weight.
i tried to buy a set off a local member but he disappeared. i must say, those look pretty nice on a roll. sometimes its all about the bling baby!
dallas
vancouver BC
The Startech's on that Viper are 19/20 not 20/20 . Those Startechs with pirellis's are about the same weight as the stock wheels and runflats . Reason being run-flats tires are very heavy compared to a non run-flat radial.
SPARTICUZ
Richmond,B.C. Canada
OK Here is a revised post of my research on the different wheel tire set up.
It turns out my Startech '19 & '20's with Pirelli Rosso tires is 51.9 lbs heavier than stock 18' 19' with Michelin Pilot run flats.
Not too bad considering bigger wheels and better tires :) Plus I save lots more weight since light weight RPS Flywheel thanks to Dallas :)
STOCK SRT-10 WHEELS
18' Front
8,051 grams
8.051 kg
17.71 lbs
19' Rear
12,701 grams
12.7 kg
27.94 lbs
TOTAL = 91.3 lbs
STARTECH WHEELS
'19 Front
17 kg
37.4 lbs
20' Rear
21 kg
46.2 lbs
TOTAL = 167.2 lbs
Michelin Run Flat Tires
Front P275/35ZR18
31 lbs
Rear P345/30ZR19
38 lbs
TOTAL = 138 lbs
Pirelli Rosso Tires
Front 275/30/19
27 lbs
Rear 345/25/20
30 lbs
TOTAL = 114 lbs
http://www.tirerack.com/tires/Spec.jsp?make=Pirelli&model=PZero+Rosso&tirePageLocQty=
http://www.tirerack.com/tires/Spec.jsp?make=Michelin&model=Pilot+Sport+ZP&tirePageLocQty=
SecureOpossum
