02 RT/10 Questions
Robert Dyck
Pembroke Pines, FL
Just purchased an 02 RT/10 and I have some questions, please.
1- The radiator fan seems to run much of the time. My 97 GTS fan did not run nearly as much. Is this normal?
2- What is the factory-recommended break-in procedure?
3- I will install Eibach springs to lower and re-align. Has anyone done this?
4- Has anyone retained their stock exhaust system, using high-flow cats?
Thank You.
AJT
Houston, TX , USA
1. I don't hear it much over Corsa & hi flo cats.
2.
" 0 -200 mi < 2500 rpm
200 - 400 mi < 3500 rpm
400 - 600 mi < 4000 rpm
600 - 800 mi < 4500 rpm
800 - 1000 mi < 5000 rpm
All LIGHT THROTTLE RUN - UPS
Keep vehicle below 70mi for 1st 1000 mi
Oil change @ 200 mi
Oil Change at 1000 mi
Avoid excessive ideling
Check oil level every fuel fill up"
All info per Herb Helbig Team Viper
3. No, rubs driveway as it is.
4. Corsa & metal substrate hi flo cats ( Thanks John @ partsrack)
Alarm deactivate is in glove box. There is a keyhole in the top of the glove box for deactivation.
Hope this helps
Andy
