08 Viper w/out mufflers (Sound clip/vids)
Malu59RT
Dallas, TX
I was hesitant to spend money on the Corsa's after hearing that the catbacks for the 2008 really didn't make the cars any louder, so I figured I would try the car with open cats, and a straight pipe to replace the mufflers. The car sounds almost the exact same at idle and cruising in 6th gear at 80mph. Startup is more aggressive, and the car likes to pop a lot more. When you are on it, it is pretty aggressive from the outside. Not a bad deal for $200. I will re-dyno the car soon to figure out how much power I have lost without the mufflers and will report back when i can.
Jason
Sound clips/vids:
Start-up/partial rev above sidesill on driver side with door open:
2nd gear and 1st gear acceleration video:
Decel with popping / low speed in-cabin sound:
M
Malu59RT
Dallas, TX
Just curious why you didn't do with HF cats? Cost?
I didn't want to mess with anything that would throw a CEL (although this gave me a scare 2 weeks ago). If I lost a substantial amount of hp, then I will go back to the stock mufflers, but right now I'm enjoying the sound.
needs headers
Don't get me wrong, I would love to own a set of Belangers, but that won't be anytime soon as I have a lot of other things I need to be spending money on. I actually had a couple of VCA members think that it was a Belanger setup when I drove up to a meet Saturday night (they brought their Belanger equipped 08 Viper). It actually sounds better in person than what I could record.
Jason
got one
Castle Rock
Jason, that car is wicked sounding!!! Hearing it person...ya, the audio file doesn't do it justice. And sounded great on the highway when hearing you pass someone.
CitySnake
Manhattan, USA
Why would HF cats throw an engine light? From my understanding, the HF cats give you close to the same sound as straight pipes (removing 2 mufflers from the OE setup) and add HP.
It's all a matter of opinion anyway. I guess everyone finds their own path to the same place. :)
pteam
Cleveland Ohio
That doesnt sound like really loud... I thought no mufflers and no cats would be insanely loud, to the point that other members in previous threads talked about ear plugs... it should be no where near "The car sounds almost the exact same at idle and cruising in 6th gear at 80mph"
Nine Ball
Houston, TX
damn that has to be loud as f-k in the cabin. Mine has high-flow cats and Magnaflow mufflers, and it is still too loud to me at ~1800-2200 rpm.
Jeff Monheim
I swapped out the stock mufflers and went to a very small magnflo muffler
(18" long by 4" diameter) kept the stock tips, the sound hardley changed just some popping actually more like thunder rumbling (I do like the RUMBLE)when backing down at about 1500 rpm. I also read about the ear plug thing, which kept me from going to straight pipes from the cats back. I think if I change again I may just eliminate the second cat or "hollow" it out. to keep the stock look and length and reduse expense! Cost was $298.00 all 304 stainless. I will have some 400 series stainless made to extend the tips out about 1/2" when I do the next exhaust mod. Should have done this the first time
M
Malu59RT
Dallas, TX
Hardly the case Tony. The reason I did this is because when I called Hennessey, he even said his muffler's didn't make the car much louder. He said on the 2008's, I'd have to get headers to be louder, and he's right. Now, if I like to keep it at 3,000 RPM, there is a drone, but I'm rarely ever just cruising around at 3k
Exactly, it pops more, which I love, but not that loud. I need to have someone drive it WOT for me so I can hear it. I've heard it sounds good on acceleration, but most of my friends that I've driven next to said they didn't notice any difference when putting along.
Jason
BarryLB
