Dave's Big Brakes
Another great product from Dave's Big Brakes
Big Brake Kit for 17" OEM Wheels Fronts only.
This kit uses SRT-10 front calipers with OEM Gen2 13" front rotors, this kit comes with spacers & ET lug nuts for caliper to wheel clearance. My DVS-006 Adjustable Proportional Valve kit is required, as it gives you the best balance, and S/S DOT flexlines if not already installed.
Calipers & rotors, and pads not included in this kit, and are available thru Parts Rack, Tators Dodge, or any Dodge dealer. Your oem rotors work ok, you'll only need calipers & pads.
DVS-019A 17" OEM Big Brake Bracket Kit $495.00
DVS-004 DOT Brake Flexline Kit $259.95
DVS-006 Adjustable Proportional Valve Kit $175.00
Your choices for the rear are:
Tom's 40mm Rear Brake Upgrade( BUY DIRECT FROM Tom)
Reuse your oem rear brakes.
This Kit is only available for the first 10 prepaid buyers. I won't build the brackets without prepaid orders. I put up a thread on this deal, and only got 3 people that said they want a set. I have the bracket proto type completed, and will only have to do a production run. All the mockups have been done for fit.
Thanks Dave
www.davesbigbrakes.com
858-382-4713 cell
Thanks Dave
858-382-4713 cell
