1996 Engine same as 92-95?
AndyMac
Saint John, NB, Canada
I've been looking but can't seem to get a straight answer on the 1996 engine. I have a 95, and found a smoking deal on a 96 motor, and want to pick it up for a spare if the essentials are the same. (20psi, here I come!)
Any help would be appreciated!
Fort Lauderdale, Florida.
Same engine. With the exception of the cam gear, that is a VERY easy swap.
The harness is a little different but will work as well; you would have to swap a couple of pin-outs and add one wire.
It will work w/o a problem. Good luck!
Regards,
Doug
A
AndyMac
Heavy is good, heavy is reliable, if it doesn't work, you can always hit him with it.
- Boris the blade
Don't count the gen1 blocks out, they are beefier and have a sturdier main cap setup.
Qdog
