2000 ACR Dynamic Coil Over Rebuild.
jrod_okc
Oklahoma City
Need some help. I pulled my rear Dynamic Coil Overs today, and they both are blown. I need to get the Rebuild ASAP!! And will they be able to re valve them for my application>?
Another Question. Can i bolt on the Older Koni Style onto my car? I just need some ASAP.
01sapphirebob
"OIHO"
Last I remember there was only one place to get the Dynamic shocks rebuilt and I believe they were overseas.
Cape Coral, FL
Don't quote me, but I believe Dynamic is located in Ontario Canada? I could swear I have seen their building up there.
01sapphirebob
"OIHO"
I don't see why the Koni's would not work. I just can't remember the reason why Dodge switch to the Dynamics.
BW96snake
Carl Haas Automobile Imports Inc.
500 Tower Parkway, Lincolnshire, Il
60069
Phone: (847) 634-8200
Fax: (847) 634-8208
E-Mail: [email protected]
Ask for Trent, tell him Andreas said hi!
I'll be about $400-$500 for two rears. Unless you scratched the tube inside...
Yes, they can re-valve it for your application. The adjustment is VERY wide though, doubt you need to re-valve.. E.g., rebound can be adjusted from 150 - 1100 lb.. Trent can answer all your questions.
Yes, Koni ACR shock will fit (if for the same gen)
VIPER BAZ UK
ENGLAND
I Had a set rebuilt here in Norfolk UK where they were built,, They even had two sets brand new on the shelf.....
J
jrod_okc
Oklahoma City
Thanks for the info guys.. I bought a set of Konis for the time being, and will be sending these off! Thanks again!
BW96snake
Yup, that is the same place I posted. In IL, ask for Trent.
[UOTE=scoobie;2941593]
[/QUOTE]
X-Metal
Indiana
let me know if you need help. i am a race tech suspension center and i have done more than a few.
we service Koni, Ohlins, KYB, Penske, Showa,Fox, WP. pretty much any rebuildable shock, we have it covered.
Mopar Boy
Ontario and Ohio
Correct. But they do not deal direct. They send you to....
60069
Fax: (847) 634-8208
Carl!!
One thouhgt. Dynamics were only used on the 02's. Yours should have a Koni. Why does yours have a Dynamic?:dunno:
Mpcc
