70 MM throllte Bodies plus more
Mike Adams
guelph, Ontario, Canada
I have for sale a set of Used 70 MM throttle Bodies. These are accufab polished throttle bodies. The come with allen head screw to fit stock trottle body. You can put these on a Roe Super Charger but will have to use Seans bolts to attach to intake tubes. I also have a Roe Modified air box for 3"intake tubes for sale.
FE 065
MI
How much is the 3" airbox?
Does it have the plastic or stainless 3" inserts?
Are the inlet tubes the same width apart as OEM or wider for a blower car?
