Have not achieved anything yet. That 780 rwhp is only at 4800 rpms. That is when I do run out of fuel.I am in the process of installing the fuel system now.
I am not sure what the top rwhp will be when the motor gets all the fuel it wants.
I will keep you posted.
Matt
Here's what's involved with new rods; Oliver rods anyway. This is their reply to my inquiry:
"Most of the rods that we sell for Vipers are standard Chevy 6.125" rods. When these are used, because the Chevy crank and the Viper crank are different sizes, either the crank or the rod must be changed.
We can open up the big end of the rod to accommodate the Viper bearing, but the bearing tang locations are also different so we have to machine new tangs on the other side of the bore.
Rather than doing this, most people grind the crank to Chevy size. This does several things, some of which are, if the crank is machined correctly, you end up with a better piece with better tolerances and finish than the factory piece.
Next, because of the popularity of Chevy racing parts, you end up with a better selection of bearings. For pistons, we recommend either CP or Ross. I hope this helps. Let us know if we can be of any other service.
Thank you for considering Oliver for your racing parts needs. "
Keep up the good work and R&D blown GTS!
Thank you for the information and positive post.It is quite refreshing to actually see a positive post on this board for a change. Matt
Damn, if everything works out well for you, especially with the power you already have down low, your car is going to be just sick. Hows the torque curve on the dyno so far (unless you posted it and I missed it)?
Sounds like you have a good mechanic, but good luck with everything.
Gerald and Janni, let me get this right you are saying 9 to 1 is dangerous?By standard defintion that would be very rich. Dumba**!
Figure out what you are talking about before your next post.
Gerald since you don't know anything more than an armchair quaterback call your "level 2" mechanic or Heffner or Paxton or anybody that knows anything and they will also tell you 9 to 1 is rich. You people need to take a crash course in engines. I do not know much but damn you make me look smart. Again, Charlotte is not far for you Janni, and Gerald I am not sure where you are but come to my shop and bring your wallet anytime. Pleeeezzzzeeee! Matt
