94 RT/10 REAR NOISE-HELP????
Phil Lee 94 red RT
Cedar Park,Texas,USA
I think I might know. This happen to my 94. Check the hub nut. Remove cotter pin from hub nut. The nut might seem to be tight by it's not. Use a 3/4" drive ratchet.I think the nut is 1 1/8". Tighten nut and install cotter pin. Give it a try, it fixed mine. I don't know the torque that it should be but I was told that there is a TSB on this. Good luck!
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by halfsmoke53:
STILL HEARING A NOISE (METAL AGAINST METAL)IN THE REAR OF THE CAR ON ACCEL AND DECEL. <HR></BLOCKQUOTE>
"Noise" ???
Scrape?
Clunk?.......(most likley candidate-normal)
Clank?
Ping?
Scratch?
Thunk?
Grind?
Crack?
Pop?
Hiss?
Screetch?
Moan-Groan?
dansauto
gillett, pa, usa
In the rear, but sync the throttle cables helped?? That doesn't make sense, noise in the rear should not be related to throttle cables. get the car on a lift and start by hand spinning rear tires, check your half shaft universals, rear brake pads, wheel bearings, drive shaft and drive shaft universals, ect.. The symptoms you gave indicated a drivetrain noise.
