A/C question ?
homesite
Does the A/C compresser shut off at wide open throttle in a 94 Viper for more performance?
luc
Paso Robles CA
Homesite,
why the question? is that because the air flow from the vents stop when you are at WOT ?
Luc.
00GTS
Roadkill
Norcal
Interesting that you ask this as i noticed the same thing on my '94 when i hit WOT.. AC turns warm immediately
luc
Paso Robles CA
Roadkill,
It's a design flaw by DC that can be fixed for a couple $ and 10 minutes.
If you are interested I can explain how to do it.
Luc.
00GTS
99 R/T 10
Enterprise, AL USA
design flaw?! I thought that they wanted it to cut off when max power is damanded, so they shutdown a component that ***** a little power from max?
luc
Paso Robles CA
I'm not talking about the A/C clutch being cycled off at WOT.
Go to search, GTS & RT10, and input A/C vent, there is an explanation of what happen at WOT.
Luc.
