a/c Suction line replacement Help!!
Darell
HELP!!! im replacing the suction line on my 97 gts it was removed by the last owner for racing. i need to know what i need to remove to install the suction line on the a/c. does it install form the bottom up or side/ top down? do i need to remove the splash shield over the wheel? thanks i really need to get the a/c hooked up it is very hot in Kansas. Thanks everyone for the great forum.
Darell
dave6666
Darell
Have you considered purchasing a manual? You'll use it more than you think.
D
Darell
I do have the dodge service manual, all it says is lift the car, it is very none descriptive. im thinking in need to remove the inner fender/ splash guard?
dave6666
Sometimes factory manuals do amaze me. My 2 volume set on my '02 Super Duty has over 120 pages on squeaks and rattles, and 1 page on working on the cooling system. Which was my first anticipated project. Radiator flush, not squeaks.
I have an '01 GTS. I'll take a look and see if I can see how the hose might go on. It sounds like though that with the manual stating you need a lift, that it goes in from the bottom. Kind of a no brainer on that I guess.
D
Darell
News flash for anyone looking to replace this or any a/c hose I have now installed all the a/c hoses, the trick for the suction hose was to remove the splash guard/inner fender on the passenger side, the plan is to use rivnuts on reinstall instead of the rivets. :drive:
Dale04SS
