Well, I'm not too sure how much weight transfers to the back during a shift under deceleration, but the momentary changes in tire load are worth mentioning.
Under braking, the rear wheels are being slowed by the calipers. The rear wheel is being driven by the momentum of the car and also of the drivetrain. Depending on the engine speed, rate of deceleration, flywheel, etc, the brakes may be also be slowing down the engine or the engine may be helping to slow the car. The latter is true in city driving, but not necessarily true on the track.
Consequently you may be threshold braking and when you depress the clutch, you may lock up the rears because now they don't have to slow the engine. (I know, given the weeny brakes in the back of a Viper, you've probably never heard of this.)
And we need to do some math - downshifting to 2nd at 90MPH is putting the engine right around the fuel cutoff RPM, which means you will definitely approach the landscape in a rearward fashion.
