thebigsnake
My '00 Acr idles nicely at 750rpm when the outside air temperature is under 75 degrees. When its a hot day, above 80 degrees, it idles at 1250rpm. This is very annoying as it compounds the effects of the heat. Is there an easy fix like a temp. sensor or something I can change. Its not a mechanical linkage problem. I've already done that Sean Roe plug with a small hole thing in the hose.
Jerry.
Jerry.
