Part of the bouncing issue you have is due to the excessive rear spring rate that accompanied cars that were equipped with the Dynamic shocks. My understanding is that most guys dumped this shock set up who were actually racing their cars. Even the ACR's with Koni's will jump to the next lane on bad asphalt. As far as adjustment, the Koni's only use a "spanner wrench" for ride height adjustments. The spanners can be purchased from McMaster-Carr. The Koni equipped cars did not include any spannners, nor are they available through Koni or Dodge. The correct part # for the Koni 2812 Race Damper is McMaster-Carr #55165 A41. You need two wrenches to do the job properly. For those of you with the Dynamic shock if you can't figure out how to choose the proper tool, let me know and I will guide you through the process.
