Advice on door wiring harness.
747Capt
Has anybody replaced the driver door wiring harness? How big a job is it and is the harness avalible from Dodge? First mirror, then outside door release, inside door release, all quit in that order. Now door speakers intermittent. apparently not an uncommon problem on 2000 RT/10. Would like to avoid what could be a large installation charge as car is out of warranty. Any advice would be appreciated.
Schulmann
Canada
I have an ACR and I had to rewire everything for a custom stereo. It can be done but requires to remove nearly everything from the door. As far as I remember likely you can keep the glass in place but you will have to remove the door. All depends on who is doing the job ... and you need space and time that's it.
Mando9595
