airbag disable question
hemibeep
Tampa FL
Will pulling the fuse for the airbag disable it? I know there is a capacitor that must be allowed to drain down.
Have a steering wheel change coming up.
Warfang
California, East Bay
What? you don't enjoy playing "Hindenberg Roulette"? :D
On a similar note, does the fuse disable both airbags? I'd like to give my little niece and nephews a ride, but my 97 doesn't have passenger side disable.
kcobean
Sterling, VA
If the answer is "no" and/or you want to have the easier ability to disable the airbag when needed, check out http://www.airbagonoff.com. I had one of their switches in my 350Z so I could take my son for rides in the car. They came to my house to do the install, did a top notch install job, and the switch they offer is apparently the best aftermarket switch available.
jcaspar1
Sacramento, CA
Pulling the fuse will disable both airbags. That's what I do when I used to take one of my baby girls for a ride.
97 B/W GTS
Dallas, Texas
Hemibeep: The tech that maintained my '97 before I bought it, told me "off the record" that pulling the fuse would disable it. He of coarse couldn't recommend that I do that though.
Warfang: I have always assumed that since there are two fuses and two airbags, that pulling them both would disable both.
I have kids and they love to ride in the car so I regularly do this.
carguy07
Cuyahoga Falls, OH, USA
I would double check with the Wizard on this one. I swear I remember reading that the fuse is not enough if you are servicing the steering wheel. It could just be the capacitor thing, but I would make sure before going in there.
Marv S
Scottsdale, AZ
Re: airbag disable answer
There was a kit from Dodge to add an airbag switch to 96 & 97 Gen 2 Vipers.
NHTSA approved it
Make : DODGE Model : VIPER Year : 1997
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 083799 Date of Bulletin: NOV 12, 1999
NHTSA Item Number: 6089800
Component: AIR BAGS:ON-OFF SWITCH ASSEMBLY
Summary:
DAIMLERCHRYSLER CORPORATION IS NOW OFFERINB AIRBAG ON / OFF SWITCHES FOR SELECTED VEHICLES. *TT
Service Bulletin Num : 081798 Date of Bulletin: DEC 30, 1998
NHTSA Item Number: 603153
Summary:
SUBJECT REGARDING AIRBAG ON - OFF SWITCHES. *YC
An important item was how the kit grounded the airbag when the switch turned it off.
While a mis-deployment would be very rare, just pulling a fuse or disconnecting leaves the circuit vulnerable to an electric static discharge that could deploy the airbag.
also, the kit only allowed you to disable the pass. side airbag - not the driver's side.
This lets you disable the driver airbag:
Service Bulletin Num : 970919083297 Date of Bulletin: SEP 19, 1997
NHTSA Item Number: 54423
Component: AIR BAGS
Summary:
AUTHORIZED AIRBAG DEACTIVATION FOR MEDICAL NECESSITY. *YC
Warfang
NHTSA approved it
Summary:
Summary:
Component: AIR BAGS
Summary:
Where can you order this?
Marv S
Scottsdale, AZ
I got my kit from Nancy @ Woodhouse many years ago.
The Dodge Part numbers I got were :
05011483AA for the switch and
0LB38JX8AH for the dash piece bezel.
That dash piece is from a 98 and has a different texture than a 96-97
Ron had a new one he never used. Don't know if he ever sold it. [email protected]
You could likely just get a bezel with the switch from a 98-02 parts Viper and install. It's not too difficult.
Flash Gordon
Motown, NJ
NHTSA approved it
Summary:
Summary:
Component: AIR BAGS
Summary:
I'm interested, as well. Lemme know if you find out anything! :D
Qdog
