Another half shaft bites the dust.....(new best time)......(race info).....
1TONY1
Dalton Ga. (Chatt. Tn.)
Well, last night I joined Cudaman and Roof. The left shaft gave way....have not looked close enough to see if it was a u-joint only or the Unitrax shaft itself. The quarters are setting on the tires....we could see that the lower left shock mount (wishbone) is busted. There may be more damage but I got in late and the car is still on the rollback. On the upside, Our local annual charity street car race (1/8 mile)had 140+ cars. Joseph Dell came up from Atlanta, Mike Robbins, Mark G (VCA board member) and myself. Joseph made some nice driving improvements knocking over a second off his first et slip and finding the limits of 850rwhp and drag radials. We had just gotten the Roe supercharger on Mikes Venom 650R Friday and with very little road tuning he was in the sixes. Mark was running gen2 times with his gen1 on Michelins without his n02. I beat my best time to date by .25 and 3 mph with a .07 worse sixty foot time.....ran a 6.52 @ 108 and was leaving a little soft (for me),good enough for #1 qualifier in the e.t. street class. Will post damage results later.
Dr Roof
Louisville, KY usa
Bad feeling when the half shafts go bad! I hate IT!!!
Tony with all the improvements and Mikes car together you Mike and Joseph need to load up for TEXAS!
Sorry about the shafts I know the feeling!
J DAWG
MS
Well, I guess that means you will be begging the wife for the keys to the SRT.
ps - you leaving the line soft my a$$. lol. :D
1TONY1
Well it looks like the shaft is good except for alot of beats and bangs. It broke the u-joint and busted out both sides of the shock mount. I also wonder about the hub, it broke two of the u-joint strap bolts off in the hub....they will come out, but are the cap holes still perfectly round ??? I need to find a "pre owned" shock mount and possibly the splined hub shaft (my name for it) The only way to get a new hub/shaft from Dodge is to order a complete stock halfshaft and I'll be darn if I will do that.
utahviper
Utah
With that 1/8 mile time you should be low low tens.
Contact John partsrack. He can probably point you in the right direction for used parts.
1TONY1
The halfshaft is binding inside and is pretty rough around the u-joint cap so it is going back to unitrax for rebuilding. Seems like unitrax is there to please and take care of us racers.
countourcafe
